Problems sending mails through smtp
smtp authenticate
7 replies to this topic
#1 hawkings
  • 1 posts
Posted 18 April 2012 - 08:01 AM
Since my upgrade to LiveZilla 4.1.0.3 I have not been able to send emails (e.g. transcripts).
When I test the send function in the admin setup I get "Test email could not be send <...> SMTP Error: Could not authenticate." which is weird since my SMTP does not require authentication, and it worked perfectly before upgrading.
I have tried against two different working smtp servers, but I get the same error, so I fear that the latest version of LiveZilla has introduced an bug.
Best regards,
René Truelsen
#2 Derek Punzova
  • 6057 posts
Posted 18 April 2012 - 09:56 AM
Our old solution was working for most users but it had many drawbacks so we decided to use the wide spread standard solution phpmailer which was integrated in 4.1.
I think that phpmailer requires your smtp server to require authentication.
#3 gabu69
  • 206 posts
Posted 03 March 2013 - 12:24 AM
We recently moved to a centos machine and we have everything instelled properly, however we get this error
when we check the ssl encryption
The test email could not be sent!
Error: SMTP error: Could not connect to SMTP host
If we dont select ssl encryption we get an error saying:
Error: Smtp error: could not authenticate <p> smtp server error 5.7.0 Must issue a STARTTLS command first <p/>
how can this be fixed?
  • 603 posts
Posted 03 March 2013 - 07:13 AM
Hi Gabu,
Please make sure you PHP installation has SSL support (look for an "openssl" section in the output from phpinfo()).
LiveZilla uses the stand class PHPMailer for sending emails. I did some research and found many suggestions on how to fix this on these pages:
http://stackoverflow...rough-phpmailer
http://stackoverflow...s-command-first
Hope this helps.
#5 gabu69
  • 206 posts
Posted 06 March 2013 - 12:49 AM
Yea we do have SSL support
and problem still continues :S
any other way to make it work?
#6 gabu69
  • 206 posts
Posted 09 March 2013 - 06:57 PM
anny further help in this thread? I mean we have SSL support what else could it be?
#7 gabu69
  • 206 posts
Posted 15 March 2013 - 12:08 AM
is there any further help or this will be ignored?
#8 Derek Punzova
  • 6057 posts
Posted 15 March 2013 - 07:07 AM
What kind of help do you expect more? Please note that this is a problem with your webserver.
There's a ton of information in the threads posted above, also you can easily track down this problem yourself. Please understand that we cannot do this for you.
